I am trying to prepare AutoCAD files from R14 to open in Adobe Illustrator.
The issues is that the file has text which cannot change kerning, or change justification. When the text is changed to Mtext it does both. Files that are .dwg brought into AI must have Mtext or the fonts are replaced (shx vs. ttf) with a default ttf font. Is there a way around this that can be put into a script?
I am using AutoCAD 2014 and AI CC.
Solved by pendean. Go to Solution.
The TTF fonts don't appear in the drop down list. I've verified that they are in my Windows folder (installed, not copied) and also in the AutoCAD program file font folder. I've reinstalled, restarted AutoCAD, and restarted my computer.Other TTF fonts are listed in the Text style drop down list but not the RomanD and RomanS fonts required. Any suggestions?
There are no stick-font TTF files, you have to replace them with 'real' TTF fonts like Arial or similar.
If you want stick fonts (romanS and RomanD) you're stuck with using SHX fonts, AutoCAD only uses those ttf fonts for visual display.
@tami_peabody wrote:I am trying to prepare AutoCAD files from R14 to open in Adobe Illustrator.
2014 or R14?
