I am trying to insert a block into the drawing. Selected the right block and picked the insertion point but after clicking the insertion point in the drawing, It is not doing anything. It just doesn't show anything. ALmost tried 20-30 times but still not getting it. Can Someone help me out?
Naveen
Solved by GrantsPirate. Go to Solution.
A layer in the block is frozen in the drawing?
or
The block is defined a long way from 0,0 so it is coming in but is way out there,
or
You are getting an error message and not seeing it at the command line.
or
The drawing is not set to the World UCS or the block was created outside of the World UCS.
Those are my guesses.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Start a new file.
Insert your block.
Save the file.
Attach the file here and end all doubt.
Thanks guys for helping me out. I had to change the origin location in the block so that it inserts at the right location. After doing this, I found all the other Inserts which were done before.
@shanaemontaque28 wrote:
how did you do that because im having the same problem
>Here< is one example of a routine to give a block a different insertion point.
