AutoCAD 2013/2014/2015
Active Contributor
sam__gleeson
Message 1 of 7 (227 Views)
trim
227 Views, 6 Replies
10-13-2012 07:46 PM
Hi
I posted a file drawing of a basic symbol.....how do i trim the circle segment between the 2 red lines?
I have drawn this symbol in space....should i be anchoring it to the 0,0 co-ordinates?
Thank you for any help
if edges don't cross or at least touch the object to trim ... they can't be used for trimming.
- alfred -
Alfred.NESWADBA
Message 2 of 7 (215 Views)
Re: trim
10-13-2012 09:57 PM in reply to: sam__gleeson
- alfred -
Alfred NESWADBA
Active Contributor
sam__gleeson
Message 3 of 7 (212 Views)
Re: trim
10-13-2012 10:31 PM in reply to: Alfred.NESWADBA
Thanks Alfred
Active Contributor
sam__gleeson
Message 4 of 7 (193 Views)
Re: trim
10-14-2012 07:26 AM in reply to: sam__gleeson
I redone the sketch .. what tool is ideal for getting lines to touch circles...i keep getting either small gaps or small overhangs of lines when using circles...
I not now getting the Trim to work because of small Gap...so the lines just need to touch the circle for the Trim to work
Sam
Alfred.NESWADBA
Message 5 of 7 (190 Views)
Re: trim
10-14-2012 08:21 AM in reply to: sam__gleeson
in case of overlap use _TRIM (and the circle is the cutting edge)
in case of short distance to circle use _EXTEND then
HTH, - alfred -
Alfred NESWADBA
JDMather
Message 6 of 7 (183 Views)
Re: trim
10-14-2012 10:40 AM in reply to: sam__gleeson
You should never have gaps - draw to intersection and/or use geometric constraints.
Are you sure you have gaps?  Viewres 2000 or higher and REgen.
Are you in the BLock Editor when trying edit (a trim would count as an edit) your block?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
dbroad
Message 7 of 7 (177 Views)
Re: trim
10-14-2012 10:51 AM in reply to: sam__gleeson
The question of what context you are doing the trimming matters.  You can't trim a block except during a refedit session or bedit session.
In bedit there is no problem trimming, but there have been constraints applied to the object and so the trimming operation will likely disrupt those constraints.
