AutoCAD Forum
toolbars
4 REPLIES 4
257 Views, 4 Replies
toolbars
Hi
My PC has recently been upgraded to Windows 7. Unfortunatley now i ahve only limited fucntionality on AutOCAD.
How can i get the toolbars & command line ?
If i try the 'customise' option, i get the error message attached, it can't find the 'cui' file.
Tags (1)
4 REPLIES 4
LisaDrago
I would suggest a clean uninstall and reinstall, but I have contacted the moderator to move this to the AutoCad forum.
You may get a better response.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
AuotcAD 2010.
Recently my PC was upgaded to Windwos7.
I ahve no tolbar or command line. if itry customise command i get the error message cui file not found.
see screenshot
thanks
Tags (1)
Moshe-A
probably acad.cuix got coruppted look in folder
C:\Users\<your user name>\AppData\Roaming\Autodesk\AutoCAD 2010\R18.0\enu\Support
for these files:-
acad.cuix & acad.bak.cuix
make sure autocad is close
rename acad.cuix to acad.old.cuix
rename acad.bak.cuix to acad.cuix
restart AutoCAD
if it does not help? repair autocad installation.
cheers
Moshe
in reply to: Moshe-A
hi
i have the acad.cuix file in the directory, but not the bak file
”Boost
