I create a custom Tool Palette on my machine I copy it to a network drive when I call that pallette up on another machine
sometimes it adds pallettes of the same name with different "versions" of my pallette
Solved by cad_briggle. Go to Solution.
You have to also update "Profile.aws" from the below folder:
%appdata%\Autodesk\AutoCAD 2014\R19.1\enu\support\Profiles\
JCLaidler is correct, the Profile.aws contains many of the settings/pathing information which is user specific. Typically if one user is accessing a network stored tool palette collection then the Profile.aws from the user who created the palettes should be copied to the other user's roaming folder as well.
Volker
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker C.
SR Technical Support Specialist, KDE
Autodesk Customer Council | Only One AutoCAD | AutoCAD Blog
So I need to copy it from my machine to each machine
and also will this make every users profile the same or just the tool pallette's the same
Yes, we accomplish that via script. Example shown below.
xcopy "backup location"\profile.aws "%appdata%\Autodesk\AutoCAD 2014\R19.1\enu\support\Profiles\<profile name>" /y /s /r
My Users have changed their profiles adding buttons etc....
Will this overwrite them to what my profile is
(my machine is where I created the Tool Pallettes)
which is very generic
We have a 'User Custom' tab, for our users to store any custom blocks/commands.
If you have it setup that way, it shouldn't.
unfortunately we do not have it set up that way (user custom tab)
so in order to use my custom pallettes
everyone will be using the same profile (mine)
or
they will have to spend time and redo any changes they
have made to their profiles and place them on a "user custom" tab
so i guess i need to go back and re-think how to tackle this
Thanks for all your help
