Is there a way to make a tool palette created in 2015 compatible with earlier version of AutoCAD ? 2011 in my case.
When i mean compatible i mean not "read-only" i want to customize it between both version of AutoCAD.
Thank you.
Solved by Victoria.Studley. Go to Solution.
You should be able to use the palette with both versions as long as any blocks used are saved to ACAD 2010 format.
Sadly this is not what is hapening right now.
Here is a print screen of the message.
This tool palettes was made with autocad 2015 and loaded in acad 2011.
All the blocks are saved in 2010.
The palette is also locked when it contain only macro and lisp shortcut (no block).
Hi Martin,
Did you export the tool palettes from AutoCAD 2015 to XTP files first, and then import those XTP files into AutoCAD 2011?
Although it is not recommended that you share tool palettes between versions, you may want to try this to see if it helps.
Here is an article about exporting and importing tool palettes that may be helpful, if you haven't tried this already.
Seems to work!
However it would be more convenient to share the same folder between computer without the export/import process since i am sharing the same folder between work and home.
Thank you.
Hi Martin,
I'm glad to hear that worked for you.
If you'd like to see the sharing of tool palettes improved in the future, you can submit your suggestion via our Product Feedback Page. Be sure to include the impact this has on your business, which will help illustrate the need for an enhancement to this feature.
