I created a table from a excel data link. When i ran the table command it came in with 8 columns instead of the 6 that is in my excel file. How can i get rid of the last two columns. The area in the ribbon for deletion of columns is not active. Is there something i need to do in excel? My table style is set for 5 columns.
Solved by sovby. Go to Solution.
I ended up copying the required cells into a new file & overwriting my linked file & it worked perfectly. Not sure why i was getting those extra columns. Another data link was getting extra rows. Whatever works i guess
I fixed this by doing the following:
Go to Formulas/Name Manager
Select the reference for the column titles
Click Edit
On the "Edit Name" popup click in the "Refers to:" box
Highlight the correct column names.
Click "OK"
