AutoCAD 2013/2014/2015
faisal.aaouatif
Message 1 of 7 (642 Views)
Accepted Solution
tolal length
642 Views, 6 Replies
04-23-2013 07:51 AM
Is there any easy way to get the total lenght of selected lines (even if they are not "connected") ?
Thank you
Hello
The French routine TL, is in fact the TLEN routine coming from www.turvill.com
(So using TL or TLEN, it's exactly the same Lisp - Sorry the real author has been omitted on cadxp.com)
and it uses the .AREA which can (I agree) in some seldom case gives false results with the AREA
but I have never seen any error with the LENGTH !
ADDLEN.vlx (Command: ADDLEN) from www_cadstudio_cz
gives you the result in a SDF file (layer by layer) which is not very useful !?
Please find attached : DWG to test TL/TLEN/ADDLEN and the SDF coming from ADDLEN ...
I think that TL or TLEN is OK for the job required ...
Bye, Pat
*Expert Elite*
Patchy
Message 2 of 7 (628 Views)
Re: tolal length
04-23-2013 08:10 AM in reply to: faisal.aaouatif
Yes, by using free autolisp from web.
Other than dataextraction that takes ten pages to get total length, I still don't see why autodesk not making this an option in PROPERTIES.
*Expert Elite*
braudpat
Message 3 of 7 (614 Views)
Re: tolal length
04-23-2013 08:35 AM in reply to: Patchy
Hello
You can find a lot of them ...
But here is a French routine (in Pure Lisp) to get the Total Length any standard entities ...
Routine : TL   ( Loading with APPLOAD )
Bye, Pat
;; Totaux Longueur : ligne, arc, polyligne, cercle, spline, ellipse
;; par MNT Reponse No 18
;; http://www.cadxp.com/modules.php?op=modload&name=XForum&file=viewthread&tid=2683#pid6828
(defun C:TL (/ ss tl n ent itm obj l)
(setq ss (ssget)
tl 0
n (1- (sslength ss)))
(while (>= n 0)
(setq ent (entget (setq itm (ssname ss n)))
obj (cdr (assoc 0 ent))
l (cond
((= obj "LINE")
(distance (cdr (assoc 10 ent))(cdr (assoc 11 ent))))
((= obj "ARC")
(* (cdr (assoc 40 ent))
(if (minusp (setq l (- (cdr (assoc 51 ent))
(cdr (assoc 50 ent)))))
(+ pi pi l) l)))
((or (= obj "CIRCLE")(= obj "SPLINE")(= obj "POLYLINE")
(= obj "LWPOLYLINE")(= obj "ELLIPSE"))
(command "_.area" "_o" itm)
(getvar "perimeter"))
(T 0))
tl (+ tl l)
n (1- n)))
(alert (strcat "TOTAL Length= " (rtos tl)))
(princ)
Bye, Pat
vmichl
Message 4 of 7 (577 Views)
Re: tolal length
04-23-2013 02:15 PM in reply to: braudpat
Be careful with routines depending on the _AREA command - they may report wrong lenghts on self-intersecting polylines. Try e.g. the AddLen utility from www.cadstudio.cz/download (free)
Vladimir Michl, www.cadforum.cz
*Expert Elite*
3wood
Message 5 of 7 (569 Views)
Re: tolal length
04-23-2013 02:51 PM in reply to: faisal.aaouatif
You can try attached routine as well.
*Expert Elite*
rkmcswain
Message 6 of 7 (561 Views)
Re: tolal length
04-23-2013 03:37 PM in reply to: faisal.aaouatif
*Expert Elite*
braudpat
Message 7 of 7 (539 Views)
Re: tolal length
04-24-2013 12:54 AM in reply to: rkmcswain
Hello
Bye, Pat
Bye, Pat
Need installation help?
