Hi all.
I'm after quick solution for my title table/block - see picture.
I have few tabs whitin the same dwg - different layouts etc.. and would like to find solution how to fill in the same fields in all title blocks/tables quick so I don't need to fill in 5 tables with same fields manually - what's the easiest way to do it? Some .txt with all data typed in once or?
What do you use as a title table? Block? I'm new in development and all staff to make it quicker, and I want to create easy to use and efficient drawing border with title table/block from scratch...
Regards
CEZ
There is a lisp function called GATTE
You just need to select the attribute you want to edit on one page. Change it to what you want and GATTE will change the rest for you.
BTW GATTE stands for Global ATTribute Editor
Howard Walker
Hy
an no Gatte dont work in LT also LISP dosen´t
but look in the help vor
fields use ctab so that will be one way also SSM maybe are a good way for you
cu cw
Look into using the command BATTMAN. Inside the dialog you can select your title block. Then if you double click on the attribute you want to remain the same over all tabs, you can designate the DEFAULT as anything you want and all title blocks, in that drawing only, will read the same thing.
