I am attempting to create a 3d solid from a set of splines that I have lofted into a NURBS surface. I having difficulties thickening or offseting the drawing. I have also tried to network the surface to create a planar surface with the same resultant failure. Can someone please help!!!??
Please see below...
Many Thanks
Brian
Command: _loft
Current wire frame density: ISOLINES=4, Closed profiles creation mode = Solid
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: _MO Closed profiles creation mode [SOlid/SUrface] <Solid>: _SO
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: MO
Closed profiles creation mode [SOlid/SUrface] <Solid>: SO
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: PO
Specify loft start point:*Cancel*
Command: *Cancel*
Command: LOFT
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 2 total
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 3 total
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 4 total
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 5 total
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 6 total
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 7 total
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 8 total
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 9 total
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 10 total
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 11 total
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 12 total
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 13 total
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 14 total
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 15 total
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 16 total
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 17 total
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 18 total
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 19 total
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 20 total
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 21 total
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 22 total
Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 23 total
23 cross sections selected
Enter an option [Guides/Path/Cross sections only/Settings] <Cross sections only>: S
Command:
Command:
Command: _Thicken
Select surfaces to thicken: 1 found
Specify thickness <0.0000>: 2
1 surface cannot be thickened with specified value. Object intersects itself.
Command: THICKEN
Select surfaces to thicken: -2
Specify opposite corner: *Cancel*
0 found
Select surfaces to thicken: *Cancel*
No surfaces selected.
Command: _Thicken 1 found
Specify thickness <0.0000>: -2
Command:
Command:
Command: _SURFOFFSET
Connect adjacent edges = No
Select surfaces or regions to offset: 1 found
Specify offset distance or [Flip direction/Both sides/Solid/Connect] <0.0000>: F
Specify offset distance or [Flip direction/Both sides/Solid/Connect] <0.0000>: 2
Modeling Operation Error:
Could not offset surface as requested.
1 object(s) to offset.
0 offset operation(s) successful.
1 offset operation(s) failed.
I can confirm that with value 2 the object can't be modified with _THICKEN.
I tried the same procedure with 0.1 and looked then to the object and specially to the upper corners which are hard bended.
As you see the value of 0.1 makes that "corner" kinky, and so more offset ends in the message you get.
(see attached screenshot)
- alfred -
