AutoCAD 2013/2014/2015
Distinguished Contributor
6 Kudos
Post 1 of 9
the dimension style does not stay in the drop down list after drawing save
1431 Views, 8 Replies
04-06-2012 12:38 AM
New suspected bug, the dimension style does not stay in the drop down list after drawing save... can you check?
1,210 Kudos
Post 2 of 9
Re: the dimension style does not stay in the drop down list after drawing save
04-06-2012 01:42 AM in reply to: Exmateria
For me (AutoCAD 2013 German) it works like I'm used to.
My steps:
  • start a new drawing
  • within the ribbon I changed the default dimstyle to another one
  • I saved the drawing
  • I closed the drawing
  • I opened the drawing
The dimension style stays at the style I set in step 2
- alfred -
Alfred NESWADBA
Valued Mentor
22 Kudos
Post 3 of 9
04-06-2012 02:29 AM in reply to: Alfred.NESWADBA
My steps:
- alfred -
Same for me with English
Regards
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
6 Kudos
Post 4 of 9
04-06-2012 04:45 AM in reply to: Exmateria
To be more precise:
  1. Start AutoCAD 2013 (french version used)
  2. Create new DWG from metric template
  3. Change current dim style from the dropdown
  4. draw a dimension,
  5. click on the Save icon
  6. The current style diseapears from the dropdown, ilt's blank (but the current style remains current)
Bug seen by two different users on the french version.
1,210 Kudos
Post 5 of 9
04-06-2012 04:55 AM in reply to: Exmateria
to be most precise: look to my screenrecording.
- alfred -
Alfred NESWADBA
Valued Mentor
22 Kudos
Post 6 of 9
Exmateria wrote:
To be more precise:
Yes, I  see the same for the English.
The Dimension does not need to be drawn.
11 Kudos
Post 7 of 9
04-06-2012 06:45 AM in reply to: Exmateria
Same issue here (french release).
It only happens when I have more than 4 dimension styles in the current drawing. With 1-4 styles, the drop down list remains correct when saving.
1,210 Kudos
Post 8 of 9
04-06-2012 07:16 AM in reply to: david.duvillard
Tried it with 5 dimstyles, can't reproduce it (with German release).
- alfred -
Alfred NESWADBA
6 Kudos
Post 9 of 9
04-06-2012 07:32 AM in reply to: david.duvillard
Seems to happen when Standard is not the current style?
