What is the correct way to merge a network license file. We recently actived some additional licenses and I copied the additional license information into the existing license file.
When I do a status enquiry, only the new licenses are available. The existing ones seemed to have dissapeared ? In both cases the old and new license files are for 2015 products.
What am I doing wrong ?
Hello
Just a few ideas :
1) Have you tested your New LIC file on the site : licenseparser.com
Which result ?
2) If you have many sections with the same product (for exemple: ACAD 2014), these sections must have exactly the same date !
... ISSUED=16-Jun-2014 ...
This means for sections with ONE product : ACAD 2014 and for sections with Suites including ACAD 2014 ...
3) It's better to have ONLY ONE Header (or ALL Headers must be the exactly the same !)
SERVER MyServer 1234567890AB
USE _SERVER
VENDOR adskflex port=2080
Patrice BRAUD
Hello Pat,
The license parser website shows all licenses in the license file. The problem is that LM tools does not.
On portion 2 the issue date for the AutoCAD licenses are different. One set of licenses issued in June, this 2nd set issues in Sept ? Why would this be a problem ? As per the register once website it gives instructions to add the increment to the bottom of the license file...
