I have a drawing that is not showing the text filled. It was fine and now the text shows the outline only.
Solved by 3wood. Go to Solution.
The text is a title block located in paper space. If I make a block from another drawing file that is part of the same project and insert the block the text is still not filled. If I open the block file it is fine. The text shows correctly in cadd. However when plotted and plot preview the text is not filled.
