Hi there!
I tweeted at your AutoCAD account and was directed to this website!
I always seem to have an issue when matching text in model and layout space. For my ssignments the text needs to be at 1/8" in model space, however in layout space, it needs to be at 1/4", I was told by my professor to go to properties and add and match the scale to what it is in model space. The issue is that every viewport is at a different scale, and each time I match the scales to that in the model space the size of the fonts I get are not the same size throughout the layout. I'm attaching pictures with the properties showing and you can see that the size of the text is not all consistent. The tags with the numbers are in Layout Space, all other text is in model space.
P.S. Really sorry but it isn't allowing me to add more than three images so they're going to appear in this message. Also, it'd be really great if you had a number I could call you at or maybe do screen sharing. Please let me know.
Thank You,
-Katherine
You are using an annotative text style but you have assigned a text height in the style manager (the first image you posted) so change that to 0.
Now when working through a viewport to add text specify the height in the text or mtext command for the desired printed size, in your case 1/8". If your viewport is set to an annotative scale of 1/4" or 1/2", etc, the text will be adjusted for you based on your annotative setting.
In Model Space you will specify a text height of 1/4", again within the text command or mtext command, changing the text style first if you need a different look for the titles, etc in MS.
I
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
