Seems silly to have a auditable text height box but after you type in the number to change text height it goes back to its auto size.
Can anyone help me to get rid of the auto set?
hi have you try command>textsize ? hope it helps. thanks
at the command line enter Style
if you are using Annotative Mtext styles leave the value @ 0'-0"
if you are using Dtext (single line text) you will be prompted at first placement click to set your text height
dtext command line inputs
Current text style: "Arial" Text height: 0'-9" Annotative: Yes Justify: Left
Specify start point of text or [Justify/Style]:
Specify paper height <0'-0 3/32">:
Value must be positive and nonzero.
Specify rotation angle of text <0.00>:
these settings are based on a model space Annotative scale of 1/8"=1'-0" from a custom template file
keep in mind the text height displayed is based on a precision setting so it may be rounding up to that precision level try changing you precision to 1/256 and see if the value changes.
UNITS
