Is there a printerd document that would give simple descriptions of what each item does in the text field selection window?
I've searched around some but I'm having trouble finding anything like what I'm looking for.
Solved by pendean. Go to Solution.
You could try a google search if any such document is available.
Failing that, check the dialog box that opens when you insert a field.
All the options and possibilities are fairly self explanatory.
You can filter the field options by selecting the drop down box labelled "field catgory"
Thanks Dean.
I was only looking for a list that I could hand out to newbies.
I thought it would help in understanding how to use each selection.
Maybe I'll just try creating a screen capture and highlight some of them as examples.
