AutoCAD Forum
Temporary Ortho Mode
11 REPLIES 11
Message 1 of 12
1068 Views, 11 Replies
Since switching to ACad 2015, my ability to toggle a temporary Ortho mode by holding shift is gone. I have cecked that temporaryoverride is set to <1> and that in the CUI the shift key is set to toggle ortho mode on and off (and so is F8). What else can I try? Thanks.
11 REPLIES 11
Message 2 of 12
pendean
That's been a core funtion in AutoCAD for some time (no user addition/definition required): works fine in plain AutoCAD 2015. There is a slight delay in activation as you know, are you sure your delay is not a little longer?
Maybe you need to reset AutoCAD 2015?
Message 3 of 12
HullDrafter
in reply to: pendean
I was never told about this function. Thank you both for letting me know.
Also, I have ACAD 2015 Elec and it works fine in mine.
HD
Message 4 of 12
Unfortunately, it is still not working.
Message 5 of 12
kadmonkee8
does this command effect that?
inputsearchdelay <200>: default setting
Message 6 of 12
in reply to: kadmonkee8
That didn't work, unfortunately. Thank you for the suggestion.
Message 7 of 12
kasperwuyts
If your shift key is both set to toggle ortho mode on and off, and as ortho override key; might that not be the issue? I don't think your shift key should be set to toggle ortho mode the way F8 does, but that it should only be set as a temporary override key.
Best regards
Kasper Wuyts
_______________________________________________________________________________
If this post solves your problem, clicking the 'accept as solution' button would be greatly appreciated.
Message 8 of 12
in reply to: kasperwuyts
I turned off tempoverride, with shift set to toggle ortho. No change. I then retoggled tempoverride, and then removed shift from the temporary override menu in the CUI, and it still wouldn't work. Thanks for the suggestion.
Message 9 of 12
HullDrafter
I have a quick question only because I didn't see it listed in all of your answers. What is Orthomode set for?
Message 10 of 12
in reply to: HullDrafter
When its set off, it should toggle on, and when its on it should toggle off. It does neither.
Message 11 of 12
namhoang1235
Have you solved this problem pro?. I have new dell and meet this problems 😞
Edited by
Discussion_Admin
Message 12 of 12
RobDraw
in reply to: namhoang1235
There is absolutely no need to swear.
Rob
”Boost
