base of figure no. 2:
No 1, We start with blank command.
No 2, Went type "ID", It appear at command dialog box. Make sure Dynamic Input (F12) turn OFF.
No 3, after type "ID", press Enter. text " specify point" will be appear next to "ID". (not at bottom).
No 4, Then, it request to select point. and click to point we need. And it will show like picture 4.
No 5, If continues by hitting "Enter" or "space bar", It will repeat the previous last command and we need to select another point.
NO 6, Then copy all command dialog box and paste it in Microsoft Excel, it will be like this.
*** my PC are using Autocad 2013 and Another PC are using AutoCAD 2012. Version of both autoCAD may be not a problem of this cases.
Green Box above is My PC and how to make my PC like another PC (Blue Box)?
Thank You Very Much tmccar for this information, I have noted that new version of Autocad (2013 and above) may be can't do that. So, I should edit it in Microsoft Excel manually.
