we have tables as a standard in the office, each table is of the same table style on the same layer.
all properties for all table borders are set to Bylayer (G-ANNO-TEXT color70).
the issue is- in AutoCAD 2014 open a template dwg with the Layer G-ANNO-TEXT in the template place the table on the current layer it does not adopt the properties of any other layer until you go into tablestyles and modify the settings for all borders
is this normal or a bug?
Solved by pendean. Go to Solution.
thank you Dean
is this a new feature or just another unknown (on my part)?
