AutoCAD 2013/2014/2015
Active Contributor
4 Kudos
Post 1 of 8
System variables sorting programs (autocad2013)
401 Views, 7 Replies
07-22-2012 05:06 PM
Has anyone a easy way to compare the system variables from 2 autocads. So I can find out what setting have changed between them. E.G. my new cad 2013 can not remember the the director that I was in last. But the auto cad 2013 just beside me does remember the last directory folder is used. And my old cad2012 can ???. And I will open the first folder, that appears in the placelist. So I have to keep moving the current folder to the top each time.
Command: '_setvar Enter variable name or [?]: ?
Enter variable(s) to list <*>:
Active Contributor
4 Kudos
Post 2 of 8
Autocad 2013 can not remember current working folder
07-22-2012 05:09 PM in reply to: jason75
473 Kudos
Post 3 of 8
473 Kudos
Post 4 of 8
Re: Autocad 2013 can not remember current working folder
07-23-2012 05:47 AM in reply to: jason75
Are you referring to the behavior affected by the REMEMBERFOLDERS system variable?
190 Kudos
Post 5 of 8
Re: System variables sorting programs (autocad2013)
07-23-2012 06:45 AM in reply to: jason75
I think the difference you are looking for in your example is REMEMBERFOLDERS.  I don't think that is drawing resident.
Active Contributor
4 Kudos
Post 6 of 8
07-23-2012 04:06 PM in reply to: jason75
rememberfolders was already set to 1. I have changed it to 0 closed cad opened set to 1 again closed and opened and still the same problem.
214 Kudos
Post 7 of 8
07-24-2012 05:48 AM in reply to: jason75
You should set it to 0 and try it for a while.  I think help does a bad job of describing how that variable works.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Active Contributor
4 Kudos
Post 8 of 8
10-05-2012 12:49 AM in reply to: jason75
Do you think there is a windows that may also affect this command
