What is the system variable for keeping or deleting original 2d profiles of extruded objects? Also, does the variable apply to objects created using both EXTRUDE and PRESSPULL?
thanks!
Solved by GrantsPirate. Go to Solution.
DELOBJ, settings of 0 - 3, see help.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
An explaination, rather than a solution:
PRESSPULL works differently than EXTRUDE, in that it doesn't actually extrude the defining geometry, rather it detects where REGIONS may be created by one or more objects. It's this temporary REGION that is actually extruded. Additionally, PRESSPULL also performs boolean Add/Subtract at the same time if applicable.
I understand where you're coming from though... if I PRESSPULL a circle/polyline/etc, I'd prefer if I didn't have to manually delete the original geometry.
