AutoCAD Forum
Switching spaces changes ribbon tab
8 REPLIES 8
Message 1 of 9
adammacomber
1469 Views, 8 Replies
I am in AutoCAD 2015, this just started yesterday, at least that is when I noticed it first.
When I go from layout to model space my ribbon switches to the next menu on the ribbon, then when I go from Model to Layout it switches to the Layout ribbon menu. It's very annoying and distracting.
I did drag some of the menus yesterday to rearrange the order so that the ribbons I use most often are on the end, I am thinking that is what triggered the glitch.
Anyone have a suggestion to fix this?
8 REPLIES 8
Message 2 of 9
Jay_B
in reply to: adammacomber
Win Start Menu > All Programs > Autodesk > Autocad 2015 > Reset Settings to Default
Please be aware this will remove any customization you've done to the interface and reset it to the OOTB setup.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 9
adammacomber
Will my customization file still be available or do I need to export it first? I like my workspace and it takes me forever to get it all set up right after I lose it (I know from too much experience of losing it).
Adam Macomber / CAD Operator / SimplexGrinnell
Tel: +1 509 842 1204 / Fax: +1 509 535 5623
10010 E. Knox Ave. / Spokane, WA 99206 / USA
AMacomber@simplexgrinnell.com / www.tycosimplexgrinnell.com
[Tyco_SGLogo2013_Stacked_LowRes]
________________________________
This e-mail contains privileged and confidential information intended for the use of the addressees named above. If you are not the intended recipient of this e-mail, you are hereby notified that you must not disseminate, copy or take any action in respect of any information contained in it. If you have received this e-mail in error, please notify the sender immediately by e-mail and immediately destroy this e-mail and its attachments.
Message 4 of 9
Jay_B
I would back it up as I'm pretty sure this does the same thing as a "Reset of User Settings".
Better safe than sorry.
C3D 2018.1
C3D 2016 SP4
Message 5 of 9
ukdxb012
I believe this thread should give you some tips... http://forums.autodesk.com/t5/autocad-civil-3d-general/civil3d-2012-turn-off-layout-tools-contextual...
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
Message 6 of 9
adammacomber
in reply to: ukdxb012
That did it. It was hard to find the actual info in that post, but I found the one with the step by step and that worked. It did have to be removed though, I tried changing the property to merged as one of the posts said but that didn't appear to do anything.
Thanks for the link to the answer!
Message 7 of 9
mechsam
Hi, started using AutoCAD 2018 recently and had the same issue; going from model space to paper space changed the ribbon tab to Layout ribbon. Tried the suggested solution but it did not work for me. Thanks. Sam
Message 8 of 9
cadffm
in reply to: mechsam
I prefer to use context tab feature for Layouts, NOT remove them. But not as default "full with focus", instead "full without focus"
http://help.autodesk.com/view/ACD/2018/ENU/?guid=GUID-CCBA1348-8FC4-4094-A4FB-73A34D3063CD
Ignore picture
(example is for "arc selected", you need "Layout selected")
- Sebastian -
Message 9 of 9
mechsam
in reply to: cadffm
Hi there, this solution worked . Autocad is working as I wanted it too. Thank-you!
”Boost
