AutoCAD 2013/2014/2015
Valued Contributor
Anthonius
Message 1 of 4 (183 Views)
Switches to perspectiv​e view when saving
183 Views, 3 Replies
03-21-2013 03:15 PM
Hello...
On some 3D models, when I save the drawing, it automatically switches to perspective view and turns the sky background on.  This is irritating.
I found this old thread in the AutoCAD Architecture area from 2010
http://forums.autodesk.com/t5/AutoCAD-Architecture/Switches-to-perspective-view-when-saving/td-p/284...
However their answers don't seem to work.  Even setting the sky background to 1, then 0 doesn't work.  When I save, it reverts to a perspective view and turns the sun/sky back on.
Anyone know a decent fix for this?
AutoCAD MEP 2014 64 bit
Revit 2014
Windows 7
Have a good time, all the time.
*Expert Elite*
Alfred.NESWADBA
Message 2 of 4 (152 Views)
Re: Switches to perspectiv​e view when saving
03-22-2013 02:18 PM in reply to: Anthonius
one thread in the past with "automatically switches xxx in viewports" was solved by verifying the version of DWG you use to save the drawing. What is set in your options as default DWG-format?
And if you save in 2013-format ... can you create one drawing that shows this effect and upload it?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Valued Contributor
Anthonius
Message 3 of 4 (150 Views)
03-22-2013 02:34 PM in reply to: Alfred.NESWADBA
I always save as AutoCAD 2013.
Here's one drawing that does this all the time...
Revit 2014
Windows 7
*Expert Elite*
Alfred.NESWADBA
Message 4 of 4 (145 Views)
03-22-2013 02:45 PM in reply to: Anthonius
after a first look to your drawing I can confirm that issue, it does even not need to be saved, just change to Layout1 and back to Modelspace (after you first set PERSPECTIVE to 0).
The only chance I see (after just a few minutes) is to copy&paste your geom into a new drawing.
Sorry for the moment, at least one workaround (I hope, fitting for you), - alfred -
Alfred NESWADBA
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
