AutoCAD Forum
Sub/Superscript icon
11 REPLIES 11
Message 1 of 12
sdklbb123
464 Views, 11 Replies
Hi all,
I got this situation, on my PC I don't have the MatchProp, Sub/Superscript icon when I select my Mtext object. On the other hand on the other PC, the guy got it.
Any one having the same situation and having any clues how to solved this issue.
Thanks in advance
Cheers
Joel
11 REPLIES 11
Message 2 of 12
nrz13
in reply to: sdklbb123
Are you running AutoCAD 2015?  Those features are new to 2015.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 3 of 12
sdklbb123
in reply to: nrz13
Hi nrz13,
Sorry, I forgot to mention that we use AutoCAD 2015. Yes you are right. I install AutoCAD 2015 on 3 PCs and I'm the only one who don't have those features as shown below.
Cheers
Joel
Message 4 of 12
nrz13
Do they show up in text toolbar per my screenshot below?
Message 5 of 12
sdklbb123
in reply to: nrz13
Yes, I can see all 3.
Message 6 of 12
nrz13
I don't use the Ribbon, so I'm not sure why icons would be missing.  The only other thing I can think of to suggest is clicking on the "Formatting ▼" button at the bottom to see if the icons are hidden under there.  If it works like the MS Office ribbon, the more frequently used commands will show up while the less frequently used ones will be hidden there.
Message 7 of 12
sdklbb123
in reply to: nrz13
  Thanks for the tip, but just check before and no icons are thers, really strange.
thank
Joel
Message 8 of 12
nrz13
Sorry I can't be of more help.  Someone else here may be able to chime in with something more useful.  It's odd that it shows up in the Text Formatting toolbar, but not in the Ribbon.  It's possible something went wrong in your install and a reinstall could fix it.
Message 9 of 12
sdklbb123
in reply to: nrz13
Hi nrz13,
Thank for your time, I will try to repair or reinstall just in case.
Thank for all.
Cheers
Joel
Message 10 of 12
justshutup
Is the formatting panel present on your ribbon?
Message 11 of 12
sdklbb123
in reply to: justshutup
Yes, the formatting panel is there
Message 12 of 12
sdklbb123
Just to say that I repair without luck and after that I reinstall it without joy, really strange.
Cheers
Joel
”Boost
