Hi, When I select an extreme of a Line and this line have more endpoint in the same point and I want to move the grip of the select line, Now, with the AC2015, move the hole point, not only the line that I select, so I modify not only the line What I want.
I want only stretch the grip of the line that i select not the hole point.
There is a command to modify the action that only stretch the select object ?
Solved by Alfred.NESWADBA. Go to Solution.
Can you please look to the property window what element you have selected? Because a LINE-object can only have one startpoint and one end-points. No chance to have multiple endpoints.
From your screenshot it's not clear what is selected and what type of object that is.
By any chance ... uploading a drawing with that specific object would shorten the discussion.
- alfred -
Yes, Here is a Screen Shot of the Line that I select . And When I move is like the fist post.
Yes, no problem here is the file too...
Thanks for Answer !
I hope you can help me !
ah ok, you have used constraints ... look to >>>that content<<< of the help, there you have described what that is and how you get rid of it.
(good to have got the drawing 😉 )
Good luck, - alfred -
