i'm trying to make dynamic block for a security fire escape...
i have a block that i can rotate and i can strech. But my question is, it's possible to stretch not in line but with degrees to make a curve?
See the video, i need everytime to copy and paste a new block rotated to continue the line. It's a way to have a dynamic block that follow another direction during the strech (as a polyline)?
Thank you.
BIM Manager - HVAC and Plumbing designer ___________________________________________________________________________
Please use .Accept as Solution and Give Kudos as appropriate to further enhance these forums.
Solved by kasperwuyts. Go to Solution.
Just to clarify, you want a bend not a curve, correct? You said curve but showed a bend.
I think to do a bend, you'd basically just want to have two separate lines/arrays, one with a polar distance parameter and the other with just a distance parameter with a stretch command on each. When you need the line to be straight, you just stretch the one; when you need a bend, you've got a separate node to bend out.
Off the top of my head, I'm not sure how you'd do a curve, but I think it'd be much more difficult.
Have you looked at using an dynamic array that arrays a block and follows a path?
nrz13:Just to clarify, you want a bend not a curve, correct? You said curve but showed a bend.
I will have this for example with one block dynamic:
@Anonymous wrote:Have you looked at using an dynamic array that arrays a block and follows a path?
I don't understand what do you mean...
The block at this moment is setted with a series...
The DWG I added contains an example of a path array. There are downsides to this method:
1) the path line is an actual visible line, although you can put it in an invisible layer
2) to align the chains perfectly, you aways need to make sure the polyline segments are an exact plural of the 'between' distance.
It's very easy to add segments to the polyline however.
This is very good, but doen't exist a way to set that the series goes only step to step..If the arrow is 40mm lenght, the series linear can only have 40-80-120... lenght.
For example my block when i strech stretch only the lenght of the arrow, not more not less.
You can, but only if you are prepared to have a fixed number of line segments for your path. It's a tradeoff. You can put the array in a block and add a bunch of polar stretch parameters to your path line. Here is an example with 5 segments.
Thi is what i want! Only one thing, why in this case i can't add a new line to continue? only stretch and rotate...In the first one work...
That's because the first one was not a block, just a polyline with a path array, so you could edit the polyline in anyway you want, such as extending, stretching, , adding segments, etc... This second one is a block, and the grips are actually all individual parameters. You cant edit the polyline anymore, except if you explode the block, at which point it starts behaving exactly like the first one.
So, as I've said, it's a trade-off. You can use the second one for initial placement, then explode it and manipulate it further, and then if you want, you can still put constraints on the path to fix certain segment lengths.
-Marco-:
Kasperwuyts already illustrated what I was talking about with his second drawing. Unfortunately, I know of no other way either. Just take your worst-case scenario and put that many grips in it. Just because it has 8 bend points (or whatever) doesn't mean you have to use them all. You can still have one straight line bending into just another straight line.
