AUTOCAD 2014
I typed "S" this morning, hoping the stretch command would be triggered. Instead, the stencil command appeared which appears to be an alias for "insert". Although the alias is not in the acad.pgp, it appears to be hard coded into the program. How in the world does stencil get interpreted as "insert"?
A more important question is "How to get rid of it?". I've tried undefine. It says the command does not exist. I've tried atoms-family to see if it was a lisp defined command and it wasn't.
Does anyone know how to edit the autocomplete list? Best I can do is just turn it off.
Just a thought -- add it to the acad.pgp file, triggering Stretch as I would think the original alias ought to have been.
Good workaround. Wonder what Adesk was thinking!
No one here but me. Doesn't show up in the atoms-family. I didn't create it. Won't undefine. Thanks for the notice that stencil doesn't exist for you. Perhaps its an MEP thing. I'm using the base AutoCAD but there could be something hanging around.
Thanks for the confirmation. At least I'm not imagining it.
I just turned it off. It always annoys me. I would rather looking in help file to find out the correct command name and trying to remember its full name, or select from the menu.
@Jason.Piercey wrote:
Vanilla 2015 SP1 here. Just as you noted Stencil invokes Insert.
Same in 2015 here, but S invokes Stretch as expected, so there's obviously something else going on. Stencil is in the auto-complete list [with (Insert) following, I guess so you know what you're really getting], but it doesn't pop into the default to become what I get with Enter until I've put the first four letters in -- for S it offers STRETCH, for ST --> STYLE, for STE --> yet another similarly oddball substitute name STEPPED (OFFSET), and finally STEN --> STENCIL (INSERT).
What users should have is edit access to the autocomplete list at some level to switch off commands from the autocomplete list.
