Does anyone know how to use the /s startup switch to specify a different support folder?
I would like to add one additional support folder for a specific project, on top of the existing support folders specified in Options. It appears that it wants me to list all of my support folders, but I have too many and the switch only allows 15 max. Is it possible to add one support folder at startup without overriding the existing ones?
Solved by rkmcswain. Go to Solution.
Looks like you'll have to use another method other than a startup switch.
We set the support file search paths at startup using autolisp. If this is an option for you, I'll point you to an example of doing so.
See this page. Post back here or leave a comment there if you have more questions.
