AutoCAD 2013/2014/2015
NFornalski
Message 1 of 6 (7,833 Views)
Accepted Solution
Stack Dimension Override Text
7833 Views, 5 Replies
07-05-2012 10:00 AM
At work we occasionally find the need to override a dimension with a text description. Is it possible to stack this text?
Nick
*Expert Elite*
pendean
Message 2 of 6 (7,830 Views)
Re: Stack Dimension Override Text
07-05-2012 10:30 AM in reply to: NFornalski
Can you provide a screenshot of your desired before/after result?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
*Expert Elite*
dbroad
Message 3 of 6 (7,828 Views)
07-05-2012 10:41 AM in reply to: NFornalski
Yes.  Edit the dimension text as follows.
<>\XYour override text here
NFornalski
Message 4 of 6 (7,822 Views)
07-05-2012 11:05 AM in reply to: pendean
This is the look I am after.
*Expert Elite*
pendean
Message 5 of 6 (7,813 Views)
07-05-2012 02:56 PM in reply to: NFornalski
DDEDIT command, type it as you wish, with an <enter> keyboard strike in between the words.
or double-click on the text and when the dialog box comes up  type
CURRENT\XOVERRIDE
the \X acts as a carriage return
In your example \P may work as well (carriage return without pushing the second line below the dimension line if your sample was horizontal and not vertical.
CURRENT\POVERRIDE
Note that in the last two examples both the X and the P are in ALL CAPS, lower case does not have the same effect.
NFornalski
Message 6 of 6 (7,808 Views)
07-05-2012 03:20 PM in reply to: pendean
Perfect!
Many Thanks.
Nick
Announcements
Need installation help?
