Our cover sheets and title block grab information such as project name and description from the sheet set manager. They are updated correctly on the screen, but when I go to plot the sheets seem to gather the information from the wrong sheet set, in this case our template sheet set. I can't figure out how to get it to pull from the correct sheet set. This seems to be a problem with 2014 and not from previous versions because it started to happen around the same time. It might be unrelated to the version though. I am not certain about that.
Any ideas would be greatly appreciated!
Solved by erik. Go to Solution.
How are you opening/plotting these files?
If you're doing 1 or 2, then it sounds like you're opening the "template SSM file" and plotting/publishing. And you have another SSM file that correctly points at the new dwg file(s).
Don Ireland
Engineering Design Technician
Hi Don,
I typically plot from the sheet set manager and from the correct sheet set, either from right clicking on the sheet or on the top level group and choose publish. If I go to file/plot and plot that way I get the same problematic results. I can't find a work around at the moment.
Erik
I found the problem. Our template had recently been changed to have the titleblocks xrefed as ATTACHED. Changing the titleblock xref to OVERLAY was the solution.
The reason this worked is that when they were inserted as attached xrefs, the drawing with the plotted sheet drawings loaded the titleblock through one of the nested xrefs that was not associated with the sheetset.
