AutoCAD Forum
square to round
5 REPLIES 5
shicks32
5009 Views, 5 Replies
square to round
Is it possible to draw a Square to Round lofted sheetmetal part in Autocad 2015?  I tried using the loft command but the part doesn't look right.  I searched for a "how to" on Youtube but they only have one for Inventer.  Any ideas?
5 REPLIES 5
JDMather
in reply to: shicks32
Attach your dwg attempt here.
I didn't Shell it, but see the example here on pg 17
http://home.pct.edu/~jmather/content/CAD238/AutoCAD%202007%20Tutorial%201.pdf
shicks32
in reply to: JDMather
This is what I'm trying to draw using AutoCAD 2015, size is not important at this point, I just want to know if it's possible, and if so, how?
shicks32
Thank you for your help I'll try it Smiley Very Happy
JDMather
Add fillets in the corners and nodes to attach your Guide curves.
Of course Inventor does it for you - simply click the circle and rectangle.
nestly2
Most likely guides are going to give the best results for that shape, but there's also a lot you can do with loft settings either during, or after the loft is created.
”Boost
