AutoCAD Forum
Specialty tools
3 REPLIES 3
JBall-Cstone
180 Views, 3 Replies
Specialty tools
I have some personalized tool bars and blocks that are in autoCAD 2002 format which is not compatible with the newer versions of  AutoCAD. I need to know if there is a way to convert them to a AutoCAD 2014 compatible format and if so how?
Tags (1)
3 REPLIES 3
the toolsbars as well as block-definitions from can be used with 2014.
So it's more a question of why you think you can't or what commands are behind your 2002-toolbar-icons.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
They are customized tools that were not created in AutoCAD they are .mnc
files. When I attempt to load them into the newer versions of AutoCAD I am
told 'Customized Tools load failed'. What do I need to do to convert these
into an acceptable format for 2014?
James Ball
Cornerstone Design Services
504 Indian Trail Road
Suite 201C
Lilburn, GA 30047
(770) 717-0040
jball@c-stonedesign.com
MNS or MNU (the source version of the MNC)
- alfred -
Alfred NESWADBA
”Boost
