Hello, I've solids in series and I need to color them each a different color,if I click one ,unfortunately, it select them all, how can I fix?
Solved by nestly2. Go to Solution.
When you select the Solid, does the Properties Palette identify it as one Solid? If so, use SOLIDEDIT > SEPARATE
Ok it seems that we use different software, i use autocad 2014 and how can you see we have different home (and you can see that i'm italian).. also if i write "separate" it says that work only with groups and i have a series, don't tell me that i have to download another software..
Nope, you don't need different software. The Ribbon panels change based on the workspace. You appear to be in "Drafting and Annotation" where my animation was made using the "3D Modeling" workspace.
As stated above, you need to identify what type of object it is first in order to know how to modify it... Open the Properties Palette (CTRL + 1) and select the object.
Also, the command to separate non-continous solids is not SEPARATE, it's SOLIDEDIT > Body > SeParate solids
