I've recently installed AutoCAD 2014 and noticed when I try to select objects behind a solid (in wireframe) it will select the face of the solid and I am not able to select any objects behind that solid. In the past, while in wireframe, I wasn't able to select a solid unless an edge was selected. Now if I click on a face it will select that item, which is not allowing me to select anything behind it. Is there a variable to change the way a solid is selected while in wireframe?
Solved by bsanada. Go to Solution.
Hi, there,.............
I am facing the same prob of urs.......3d object selection !!!!!!!!! Can u please explain, how u have fixed that?
