AutoCAD Forum
solid polyline showing blank in layout
2 REPLIES 2
shavezkhan
1048 Views, 2 Replies
i using auto cad 2014 registerd version in model which solid polyline i crete than one when i check in layout that is blank
2 REPLIES 2
hwalker
in reply to: shavezkhan
Do you mean you cannot see the polyline?
If so make sure it's not on a layer which is frozen in that view port.
To test that, create another viewport and see if you can see your polyine in the new viewport
Howard Walker
Left Handed and Proud
jivkomitev2
check if in viewport in your layout visual style is set to "hidden line" instead of "2D wireframe"
also in the properties of the viewport - "Shade plot" should be "2D wireframe"
”Boost
