My drawings when exported are smudged. A brief description would be that there should be a drawing but when previewed, what comes out is that a certain portion of the drawing is smudged as if the it is painted.
Do you mind send the drawing to here?
If not smudged, what is it look like?
Is it welding? hatching by some objects?
if you change a new ctb with all pen width 0 what will happen (not use object width)?
I seems didn't see your dwg attachment
try attached test_monochrome_penwidth=0.ctb to print it again.
put your the ctb file here than choose it to print:
Thanks for the help so far. However i still receive the problem when i use 0.005 and 0 pen width. This are the results.
