for the last two months, Autocad is very slow to respond to cursor movements ONLY when I am in the LINE command. (other commands are normal)
Any suggestings?
I am using Autocad 2013 Mechanical, on a new very fast computer (i do not have any other problems with speed with other programs
Solved by pendean. Go to Solution.
Check your visual style, maybe your 3D drawings are set as shaded.
Had this before as well, and it killed performance without realizing about it.
