AutoCAD 2013/2014/2015
Active Contributor
0 Kudos
Post 1 of 5
sketch
184 Views, 4 Replies
10-12-2012 06:18 AM
Hello
I`m inexperienced at the moment.I have started a sketch but if i change dimensions say on the long thin rectangle the sketch falls apart..Also if i change a dimension on the top section of the sketch the lines move....what am i not doing
Lou
1,219 Kudos
Post 2 of 5
Re: sketch
10-13-2012 11:35 AM in reply to: lougalea
because the top section is not bound to the lower one, with other words it's not fully contrained.
BTW: please use the modelspace to design your model (not the paperspace/layout).
- alfred -
Alfred NESWADBA
2,131 Kudos
Post 3 of 5
Re: sketch
10-13-2012 05:49 PM in reply to: lougalea
Are you familiar with parametric geometry constriants and dimensions?
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Active Contributor
0 Kudos
Post 4 of 5
Re: sketch
10-14-2012 05:39 AM in reply to: JDMather
Hi
Is there a command on the screen which advises whether the sketch is fully constrained or how many constraints are needed to fully constrain
Regards
Lou
2,131 Kudos
Post 5 of 5
Re: sketch
10-14-2012 06:21 AM in reply to: lougalea
Auto Constrain will tell you how many were missing.
But really - you should know what needs to be constrained (there is no auto-constrain out on the shop floor).
You have a lot of repeated dimensions - use symmetry and equal constraints.  Use geometry constraints before parametric dimensions.
