AutoCAD 2013/2014/2015
Active Contributor
sam__gleeson
Message 1 of 7 (162 Views)
sketch blocks
162 Views, 6 Replies
10-14-2012 03:29 AM
I have started to creates some sketch blocks.The only issue i have is when i go and place them in a drawing they get placed way outside the layout so i have to drag them into the layout sheet.How do i get the sketch block to be placed into the layout..
Thank you
pendean
Message 2 of 7 (157 Views)
Re: sketch blocks
10-14-2012 05:09 AM in reply to: sam__gleeson
What does "place them" mean using exact AutoCAD command / function names?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
JDMather
Message 3 of 7 (152 Views)
Re: sketch blocks
10-14-2012 06:17 AM in reply to: sam__gleeson
Can you attach one of these "sketch blocks" here?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Contributor
sam__gleeson
Message 4 of 7 (144 Views)
Re: sketch blocks
10-14-2012 06:44 AM in reply to: JDMather
Here is a block..
JDMather
Message 5 of 7 (134 Views)
Re: sketch blocks
10-14-2012 10:45 AM in reply to: sam__gleeson
I suspected that you did not define an insertion point, but that was not the case.
Placement of your block  example is entirely predictable.
How are you placing, by typing in coordinates or On-screen?
dbroad
Message 6 of 7 (133 Views)
Re: sketch blocks
The block "XFLOW STRAINER" looks fine.  The drawing named block has one insertion of "XFLOW STRAINER".  The insertion is far away from the origin of "block.dwg".  If you try to insert "block.dwg" into another drawing it will drag "XFLOW STRAINER" far from the object itself.
If you meant to access "XFLOW STRAINER" from other drawings, use wblock to save it to a drawing by itself or drag it to a palette and use the palette to insert "XFLOW STRAINER" into other drawings.
Active Contributor
sam__gleeson
Message 7 of 7 (116 Views)
Re: sketch blocks
10-15-2012 02:55 AM in reply to: sam__gleeson
Thanks for all the replies..I open up a new I open up a new AutoCad template and go to the ISO A3 Title Block sheet..Then from the Insert Tab i insert Blocks with the Insertion Point On Screen box Ticked
Thanks,,,Sam
