AutoCAD Forum
simplex.shx problem with AutoCAD 2015
6 REPLIES 6
Amremad
6797 Views, 6 Replies
iam using AutoCAD 2015 when i using simplex.shx font name
when i add new single line text to paper space  i have this problem see picture  (no in model problem)
but when i going to edit it , i don't found any problem see picture
but when i Regenerating model. the proplem appar agian
what can i do to solve this problem
6 REPLIES 6
Alfred.NESWADBA
in reply to: Amremad
can you upload that DWG?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
pendean
No such problem here, see attached: did you "migrate" from an older version or perhaps your simplex font is missing?
Amremad
not in model space , try put your text in paper space
jggerth
check the date on your SIMPLEX.SHX file (the one that's actually being used).  There are a couple of version floating around that have been distributed by Autodesk.  The older one is not a Unicode font, the version dated 2004 is.    Ensure you're using the current version.
Alfred.NESWADBA
No problem, also in paperspace. Do you speak about TEXT or MTEXT?
Can you recreate that in a new drawing? If so, upload it, I guess it's drawing specific or just your installation. To make sure which of those 2 possibilities we need a drawing to try your drawing on different systems.
- alfred -
Alfred NESWADBA
Amremad
hi every one
thanks for all about trying helping me , i found my solution of this problem
first see this picture
the problem happen when i use the arabhol.shx with bigfont , but when i delete it or uncheck use big font the problem disappear ,
i think AutoDesk must fix this debuge becouse i think this problem will happen with another fonts , i will attach the sample of the problem and its fonts but must move the fonts to autocad folder font.
thanks for all
”Boost
