I have been asked to create a simple hatch pattern but it has been years since I've done this.
My hope and assumption is the pattern already exists.
Thank you in advance for any assitance
See atatchment
Solved by Patchy. Go to Solution.
We really need a picture to understand the details.
How much the stagger distance in X and Y direction? is there any rotation angle?
Wow,
This is ridiculous.
I am trying to attach the file but it is not working.
every time I click on "Add Attachment" my browser jumps to the top of the page.
Any suggestions?
What kind of file you want to attach?
Check the message at the top of the page (when it "jumps to the top") with explanation of the problem.
You can also try to compress file with ZIP before you attach it.
Maxim
So I am trying Google Chrome ooposed to Internet Exploder to attach the file.
Lets see if this works.
Thank you for the reply.
I tried it and am getting an error.
Attached is the file.
I must have typed something wrong.
If you're not copy and paste the code to ACAD.PAT
you have to rename the .PAT to match the hatch pattern (AR-B636.PAT) to use it as stand-alone or you will get an error.
Open this drawing and list the pattern, it works fine.
