AutoCAD Forum
Shortcut keys
3 REPLIES 3
cnweems
282 Views, 3 Replies
Shortcut keys
Are you able to set a shortcut key to a variable change? In particular I am trying to set a key to change the Osnapz to change from 0 to 1 and then back with a push of the button.
3 REPLIES 3
Patchy
in reply to: cnweems
You can use a shortcut key to turn it from 1 to 0 and then another one to turn it back with autolisp.
cnweems
in reply to: Patchy
Thank you. I guess it is time I learned how to write an autoliisp.
Kent1Cooper
For any System Variable for which the only valid values are 0 and 1, you can use a single operation to toggle between whatever the current value is and the other value [whether you assign it to a shortcut key, a toolbar button or other menu item, a command name, whatever]:
(setvar 'YourSystemVariableName (- 1 (getvar 'YourSystemVariableName)))
If it's currently 0, it ends up being set to 1, and vice versa.
Kent Cooper, AIA
”Boost
