AutoCAD Forum
Shortcut key to start right-click menu
5 REPLIES 5
efoxSMI
2042 Views, 5 Replies
Hi.  I use right-click when no command is active to repeat the previous command.  However, I would also like to be able to bring up the right-click (shortcut) menu when no command is active.  Is there a way to assign a shortcut key to bring up the right-click menu?  Maybe there's an internal command that could be tied to a function key or something?
Eric
5 REPLIES 5
nrz13
in reply to: efoxSMI
If I understand you correctly, AutoCAD already offers an option for what you want.
Many keyboards also have a context menu key that you can use to activate the right-click menu, but that behavior in AutoCAD is tied to the setting above.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
nestly2
eric.fox wrote:
Hi.  I use right-click when no command is active to repeat the previous command.  However, I would also like to be able to bring up the right-click (shortcut) menu when no command is active. ... Maybe there's an internal command that could be tied to a function key or something?
Have you tried enabling times sensitive right-clicking?  (see screencap above)  Best of both worlds, IMO.
nrz13
in reply to: nestly2
I think you still have the best of both worlds the other way too since the first option on the right-click menu is to repeat the last command.  The good news is that it's very customizable to fit many different styles, so everyone (hopefully) can be happy.
efoxSMI
Ah, yes.  Never tried that.  Thanks Nestly!
efoxSMI
in reply to: nrz13
Thanks for the reply! I actually want both repeat last command and the shortcut menu. The time-sensitive right-click turns out to be the ticket.
”Boost
