Hi i am have an issue with the shift overrides not working when there is an image under where i am working.
In the same drawing for example i can use shift to either select more than one point in a polyline, or to change betweentrim and extend or to fillet with a raduis or to a point.
but when i try to do this with an image in the background it doesnt work.
i need the image as i am tracing shapes.
thanks in advance
Solved by doben. Go to Solution.
Are you by any chance using Acad Map or Civil3D?
If so, type "MAPIOPTIONS", then under the "General" tab deselect "Shift+Left Click Image Select"
thanks maxim i have tried both of these no luck,
Doen i have a civil 3d licence using just the normal cad not the civil part for this, i have tried the mapoptions but no general tab see attached image
