There are a few Sheets that I'm not including in the printed submission. How would you suggest I add "NOT USED" to the SSM's generated sheet list?
Solved by rkmcswain. Go to Solution.
We have our sheet sets set up to utilize the *.dwg file name as the sheet number/name (i.e. - "1-floor plan.dwg" would show as drawing number one, with a description of "floor plan" in both the sheet's titleblock and the sheet index).
If we needed to make one sheet "not used" we'd change that filename in SSM to "1-Not Used.dwg". If we didn't want the blank sheet (entitled "Not Used") to publish with the set we'd set that particular sheet's "Include for Publish"option to "no" in the drawing's properties.
Hmmm..., since there isn't a software process in place to handle this, I think I'll just changing the sheet title name "NOT USED". I'll need to find place to cut~n~paste the sheet's original title, so it could be pasted back in later.
