AutoCAD Forum
Sheet Set Manager - Import Layout Query
2 REPLIES 2
Dean.Chivas
651 Views, 2 Replies
I'm trying to setup multiple sheet subsets that all have the same "title sheet" - however I can only add the sheet to one subset.
I get the following error when trying to Import Layout as Sheets:
"this layout is already part of a sheet set - not available for import"
Is there a way to have the same title sheet drawing referenced to multiple subsets??
Tags (1)
2 REPLIES 2
zalant
in reply to: Dean.Chivas
The behavior you're encountering is as designed. Only thing which comes to mind is to copy the intended layout, renaming it slightly for each subset.
Zac Travis
V08J11
in reply to: zalant
Hmmm... I wish you could use sheets twice for different subsets or files of sheet sets.  The reason for this is that you could have different sheet sets corresponding to different set purposes.
For example, in the Building Department submittal sheet set you could have your title page, your plan, your elevation and your section, whereas in a Grading sumittal will only have your title page, and your plan.  I am oversimplifying it, but this would eliminate the guesswork and time of having to pick sheets one by one on the sheet set having the all the layouts to serve different purposes.
Would be nice... any thoughts on this?
”Boost
