AutoCAD Forum
Sheet Set Manager / File Name
1 REPLY 1
cadwomen
695 Views, 1 Reply
So let´s get futher
i can´t do it , may i dont see the path .. to do
with Field´s /  or Diesel i am able to grap the Filename but what i am lookin for are to do it from the SSM ...
reason i have index sheets and there i need it
thx cw
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
1 REPLY 1
christina.davis
in reply to: cadwomen
Hi Cadwomen,
If I understand correctly, you are using Insert Sheet List Table from the Sheet Set Manager, and would like to include the drawing filename as one of the values. This is similar to your thread about adding layout names to the Sheet List: Sheet Set Manager / Layout Name
Because Filename is not one of the default choices, we'll need to use another data type to include this information in the table. I did test pasting Diesel expressions into a Custom Sheet Property, but when the table is created the field becomes "unknown."
Here's a video explaining what found, and some options that might work for you: SheetSetFilename
Please hit the Accept as Solution button if my post resolves your issue.
Christina Davis
Technical Support Specialist
Frontline Technical Support
Autodesk, Inc.
”Boost
