Using sheet set manager I drag a vew onto the sheet in paper space and the viewport is always rectangular. Since you can't edit a rectangular viewport I want to create a polyline viewport.
But if I do that and match the viewport properties it will look fine until I delete the original viewport. Then suddenly my view title loses it's link and just displays ###### for the title and sacale.
Is there a way to link that view title with the new poly viewport?
Currently I have been getting around this by keeping the original viewport on paperspace off in the corner but making it small and on a no-print layer. I just worry about someone else deleting that little viewport and then the link will get broken.
Solved by GrantsPirate. Go to Solution.
Draw the shape you want on top of the viewport. Use the CLIP command.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
