Some dwg files has a problem in VBA plotting.
I had attached files.
When you open a drawing file you can find a rectangle.
As you know that rectangle point1 is 0 0 and point2 is 1189 841.
But when you try to below ways.
=> ctrl+p / plot type set a window / set a rectangle area
you can fine a problem.
Try to below cord.
"ThisDrawing.ActiveLayout.GetWindowToPlot point1, point2"
you will get p1 is -878226, -980700, p2 is -877037, -979859
"SetWindowToPlot" was indicate wrong point too.
how can i get(or set) a correct coordinate ?
