I am trying to set up new drawing templates. I'm using ACAD 2015 Mechanical. I have created a template (.dwt file) and incorporate a standard custom dimstyle. I have gone into the template and set this new style current, again, and again, and again... and everytime I do a "new" and use my new template, that dimstyle is no longer current. HELP!!!
Does the custom Dimstyle appear in the drawing, but it won't remain "Current", or is your custom dimstyle missing entirely when using the "New" button?
Are you certain that you're using the template you've customized? Double check the path and filename for QNEW in Tools > Options > Files and/or try opening your custom template with the OPEN dialog box.
Nestly, Yeah, it's there, it just isn't current. Ideally I won't have to update the dimstyle with every new drawing.
